Thanks, now I see the difference for the pc software for mavic pro and mini. I'm downgrading, I'm using the FCC edition in europe, so if I don't downgrade, I have to use silver paper to cover the mavic mini every time i fly.
Ok. Now this is starting to make sense to me. In the prior version of DJI Fly, the "Flight Controller" serial number didn't exist. It was called the Aircraft Serial Number. Now, the About screen makes no mention of the AC serial number. There is only Battery SN, Flight Controller SN, Remote Controller SN and Camera SN.
I just checked my Spark and it now refers to the Flight Controller number as well. Aircraft controller SN is nowhere to be found. I could swear that the About screen used to talk about the AC SN as well as the Remote SN. Interestingly, the Flight Controller SN that is listed matches the RC Serial number, which isn't on its face that compelling, but when I connected my Spark to my phone directly (not using the RC), the about screen still listed the RC SN as the Flight Controller SN. I fully expected to see the AC's SN in the place of the RC SN at that point since I wasn't even connected to the RC. I find that to be odd. In any event, it appears that DJI may have changed nomenclature and is unifying across devices on "Flight Controller SN" for self-unlocking. I am sure someone will correct me if I am off base on this.
They did get back to me within an hour in fairness and it’s working now.You will get an answer in about 60 minutes as they work around the clock. It happened for me yesterday on the 31st of December.
The Unlock instructions for two distinctive ways, have been posted here.
This - along with ensuring your device has updated to the new version of the application - is good information. Thank you.Just an update for my failure to unlock and fly in a blue zone issue.
It seems that it was operator error in my case. When attempting top take off before, I was using the auto take off function and wouldn’t get any prompt to unlock the zone.
But when doing the manual take off (both sticks down and to the center), then I’m prompted with the unlock prompt as expected.
Don’t know if this is the reason others in this thread cant unlock their drone for flight, but if those haven’t already tried manually taking off.. I’d say its worth a shot.
when the popup comes on about the NFZ, I just cancel it, then use the (down in the sticks corner) to start the props then take off with the left stick. works every time for me.Weird I’m having the same issue, I even got a verification on the fly safe website, but no go. I’m going to try this when I get home. I wonder why the auto takeoff doesn’t give the same?
This did the trick for me as well! I can flywhen the popup comes on about the NFZ, I just cancel it, then use the (down in the sticks corner) to start the props then take off with the left stick. works every time for me.
Indeed thank you very much
Are you in a Red Restricted Zone or a Blue Authorization Zone?Still can't fly indoors. I did all the update and still get the message “Unable to lift restrictions”. I live in Class D airspace (3 miles just off an active runway) and I am a few 100 yards from a hospital heli-pad.
May guess is that is part of the problem, but can't I fly indoors? Winter is here, it's too cold and my flying field is buried in snow
I just noticed a circle around the drone - and part of this is in the RED area. could this be the issue?
