Using glue to repair broken plastic on rear shoulder guard
New part is the best, and it looks as if you are decided on buying a new part. As a general repair, I would consider layers of epoxy and carbon fiber in a pinch, but keep a close eye on whether the repair is holding or not. You are betting your entire drone on the repair.
Reactions: Former Member
@Thunderdrones Can you confirm price including shipping to Ireland for the same part? Attached photo. Can you confirm which side this is also? Thanks
For future reference about which is the left or right side of the Mavic when needing parts ..... It the same way you would describe L / R side on a car ,,,,,,,, From the position you sitting in it ........... for the Mavic would be the way you would ride on it lolllll
just a little humor there , but this is the way you can tell L /R sides
Reactions: Markostanley
@Thunderdrones do you have another Right Rear? I had to buy a replacement arm for this reason. I think If you have this part, I'll repair it and have a spare arm.
Hi Guys
I couldn't see another thread on my Mavic's particular damage. Basically, i had a minor crash after a gust of wind took my Mavic just slightly into the edge of some trees about 8ft u high. the drone caught some branches and fell but landed on its back thankfully but i noticed that the right rear arm had a stress crack on (not sure what its called image attached) shoulder guard flap thing.
as it is now weak and it does lift up slightly i'm concerned the right leg will not hold in position during flight and may cause it to snap off altogether.
THE FIX?
Is using glue an easy fix or does someone have a better fix for it?
I appreciate any help!
Exactly the same as me
Hi Guys
THE FIX?
I did the same thing but with a pigeon involved .. same part needed !!!
Tarizzman
