That should work ok to give you a good video feed...your signal strengths look good with full bars....are you flying in an area with high wi-fi interference? And is the video recorded on your card coming out ok?
I'm no expert on this, so maybe someone who knows what the problem is will chip in!
I don't think there should be any interference it's outdoors and no buildings nearby. The recorded video seems ok aside from it being out of focus and some jello. The focus issue is probably because I can't see what to focus on. But not sure about why there is jello the gimbal clamp is out and there does not look to be any issues with the gimbal getting hung up on the anti drop hooks. Maybe I just got a bad drone.
I am having similar issues, can't figure out anything that would be causing the problem aside from a faulty drone. Which would be super frustrating considering how long most of us have had to wait to get these things.
I went to recalibrate everthing. But when i turned it on the video feed was clean. So i took it for a quick flight and the jello was gone too. Not sure what the problem was. I did not do anything. Must be a loose conection somewhere.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
