mavicpilots.com
Since you live in Netherlands, there are specific laws and rules for you to follow, please check to ensure these are current.
As a resident of the European Union, you may fly with your drone in The Netherlands. If you fly in the OPEN category, you do not need to ask permission for your flight(s). However, please be aware of EU or national limitations that apply. For drones and drone flights in the SPECIFIC category...
www.government.nl
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Fly On and Fly Safe…
