Video important to ipad
JayTea26
Tucson
I'm new to flying and video.
I use my iPad exclusively to import photos and videos from my SD card Scandisk Extreme 256GB A2 4K HD via an adapter for my Ipad.
In my DJI Fly settings for my MA2 what should my setting be?
For example should I select MOV file format and 264 or 265 settings?
Some import fine while others do not. I get a red ! On my iPad photos that it can't seem to import vs a green check mark for ones that do.
I'm going to use Lumafusion to edit imported videos in case that matters.
I would suspect if you're editing on your iPad H264 would probably be best. The H265 codec will make processing a little more intense, requiring more processing power from the CPU and graphics card. I believe H265 would support 10 bit color while H264 would only support 8 bit (someone correct me if I'm wrong). With an Apple product MOV should work fine. Testing for yourself will give you more information.
DrDew
