Video mini 3 pro
Hello from the Crossroads of America Henk52.
I have a MA2 and I usually take the SD card from the aircraft and stick it in the PC via a card adapter.
There's a "lock" switch on the side of the adapter that may prevent the card from being read.
Good luck and welcome to the Forum. :cool:
welcome to the forum, wow it took you a while,for your first post ,since you first joined
hope to see more down the line
Good afternoon,
I recently purchased the mini 3 pro and am quite satisfied with it. I just cannot open the recorded video on my PC. can anyone help me with this problem?
What error are you seeing?
Windows or IOS? Is your computer capable of playing high resolution video?
What software are you using to play the video? Try downloading VLC Media Player.
The slide switch on the SD card adapter locks the card only for writing, not reading.
Since you live in the Netherlands (I think…), there are specific laws and rules for you to follow, please check to ensure these are current.
I cannot help you with your video issues but you should get some help here, but the best place it post issues is in the specific Sub-Forum, like "Photos and Video"; you will find more experts there as they may not be monitoring the Pilot Check In area… Also, there are tons or Videos on YouTube and there is nothing like actually seeing the procedure verses reading about it…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Greetings from the bowels of California. When you say you cannot open the video file, do you mean you cannot get it transferred to your PC or that once transferred you are unable to open the video file? If you are recording h.265 and trying to view it on Windows you will need to purchase an h.265 license for your machine.
Good afternoon,
I don't know if this will help but I just tried it and it worked great for me. Download to the phone and than plug my phone in the PC and transfer from there. The phone app seems to have more features than the controller.
Reactions: LoudThunder
Just found this. Important to connect usb first than power up the drone.
sikiruikhun
