Recently I was flying my Mavic in a very rural area. The ground speed wind was 10-12 mph. When I got straight up around 150-200' my Mavic would not follow the Litchi mission it was set for, or at least it seemed to be, trying, at around 1-2 mph, occasionally speeding up to 4 mph instead of the programmed 21.5 mph.
I had pre-checked all settings (max speed was set to 33.6 mph, wp's 1-5 were set to 21.5 mph, etc.).
So yesterday I signed up for the paid subscription of AirData UAV and checked the weather tab on that flight for that day and found out that winds aloft (around 150' and higher) were actually around 29-30 mph! It's odd that I never got a high wind warning as the drone appeared to be "drifting" as if it were in ATTI mode or something (but it wasn't). I should add that I cancelled the Litchi mission while it was barely moving, switched it to sport mode, and then I could fly manually much faster in the direction it was supposed to be going.
So does this sound like expected behavior if the winds are steady and high? And if so, why was I able to manually fly faster in sport mode but, even on a second (different) mission, the same thing happened, until I again cancelled the mission and flipped on sport mode and flew manually at my desired speed.
Would appreciate any insight into this.
