MiniPalourde
Are you 100% sure about that?
He's wrong. The arrow won't point at you if you lose GPS but it has nothing to do with the compass or new sites.
this is not true:Picking out a landmark is excellent advice MavicCF. As a general aviation pilot, we call that seat of the pants flying. Not sure why but it simply means the pilot is flying without instruments,
there are 3 important connections: GPS, RC and FPV(phone).
Below the scenarios:
Lost FPV --> available GPS + RC --> action: RTH button, or when in VLOS navigate visually, or when BVLOS navigate by decreasing distance number on the RC remote.
Lost GPS --> available RC + FPV --> action: navigate home based on landmarks, or decreasing distance number on RC remote. Be careful because you will be in Atti mode.
Lost RC + FPV --> available GPS --> action: RTH (automatically after 3 sec of no RC signal)
Lost GPS + FPV --> available RC --> action: when in VLOS navigate visually when BVLOS use decreasing distance number in RC to get back, careful you'll be in Atti mode.
Lost GPS + RC + FPV --> available none --> action: depending on settings it might auto-land on the spot, or fly until critical low battery. Due to no GPS it will drift downwind.
Notes:
[1] If you lose RC you also lose FPV.
[2] Listening to the sound of the drone can help navigating back.
[3] compass and map might help navigating back, but careful to trust compass when there are obviously already connection/interference issues.
[4] Drop from sky or flyaway are never the cause of a simple loss of signal. They are either pilot error or another malfunction in the RC, Drone, or phone.
off topic:
this is not true:
seat of the pants flying has a clear origin. Flying "by the feeling of one's *** (pants) in the seat of the plane". It dates from the Army Air Force of World War II. It means operating (NOT NAVIGATING) an aircraft (and hence any very complicated affair) by instinct and feeling rather than by instruments or other assistance.
Pilotage is navigating based on landmarks.
Dead reckoning is navigation based on mathematical calculations of speed, time, distance, and direction.
Notes:
off topic:
this is not true:
Without GPS how do you propose that the RC would be able to calculate and indicate a distance number? If it simply had dropped from GPS Navi to Atti mode I would buy that. But IMO Lost GPS fix = no distance readout.....
Sorry you are wrong, if you loose GPS and Mavic goes into Opti/atti mode the compass still works and still displays and shows Mavics orientation on your device screen.He's wrong. The arrow won't point at you if you lose GPS but it has nothing to do with the compass or new sites.
Or just hit the RTH on the RCI was flying over a large lake at sunrise and my iPad died due to cold. It was hovering way out and right in the sun. Basically had to just trial and error using sound to tell if it was getting closer. Coming from an original Phantom home lock was nice to have on the controller.
