What is the meaning of 1, 2, 3 error lights
Rseg80
NY, USA
Ok, so I bought a mini 2 used that wasn’t working thinking I could fix it but I’m stuck on the next step.
When I got the drone I would plug in the battery and battery lights would start flashing like it was charging as soon as I plugged it in but it was only the first 2. Then I would get lights 3 and 4 flashing 3 times and this indicates an smbus error so I replaced esc and esc ribbon. Same error.
I started inspecting the main board and realized the DJI water stickers were red there and on the old power supply. I noticed the contacts on the main board looked a little dirty. I cleaned them with alcohol and I now have a new error.
When I plug the battery in the first 3 lights lights sequentially like it is charging and then it switches same 3 lights but really slow 1 second a flash.
If anyone knows what this error code means I’d appreciate it.
Thanks
Rob
Is the battery in the drone charging or in a hub?
Sorry, these are the lights on the bottom when the battery is plugged in. I haven’t checked with the new code but same thing when cable is plugged into the drone.
2024mastermind
