Which coax pigtail to choose for RC controller
GravityRZ
The Netherlands
i am in the process of installing external antenna's on my rc controller.
i have both RG178 and 1.13 coax pigtails available.
which one should i choose?
1.13 is way easier to use and the u.fl connector will probably stay in place.
RG178 is a bit thicker, should have less DB loss but there is a risk that the u.fl connector will come off when twisting the cable(when reassembling)
also i read comparison between RG178 and 1.13 and there they state that the RG178 has more resistance(but less DB loss) strange because it is a thicker cable
i am puzzled, please advise.
cable is 15cm long
Ok,
since there is nobody willing to help me i do what i always do(answer my own question)
here is the answer, hopefully this will help other people.
i compared specs
on 2.5 ghz the 1.13 gives an extra loss of 1.81% compared to RG178
on 6 ghz the 1.13 gives an extra loss of 1.18% compared to RG178
so it is safe to say the difference is minimal on 15cm cable
with 1.13 you get the advantage of cable flexibility and a guarantee that the connector will not come loose(you just can not twist the cable enuogh to make it pop off)
30,48cm
freqDB/feetpercentage signalpercentage signal bij 15cmdifference
RG1782.5
-0,784​
83,4891,87007874
5
-1,38​
72,77786,60285433
6
-1,5​
70,7985,625
1.132.5
-0,98​
79,79990,05856299
-1,81151575​
5
-1,54​
70,14585,30757874
-1,29527559​
6
-1,65​
68,3984,44389764
-1,18110236​
Ok,
i compared specs
30,48cm
RG1782.5
-0,784​
83,4891,87007874
5
-1,38​
72,77786,60285433
6
-1,5​
70,7985,625
1.132.5
-0,98​
79,79990,05856299
-1,81151575​
5
-1,54​
70,14585,30757874
-1,29527559​
6
-1,65​
68,3984,44389764
-1,18110236​
Good info, thanks. I was just wondering the same thing when looking at cables.
Suilven
