Wind, again
AndreaBB
UK
Today I fired up my MM to learn how it reacts to the wind.
Windy app was showing 5 m/s and 11 m/s gusts. 6 PM, 20 deg C.
The little one went to 50, 60 and finally 75 meters with a few minutes stop at each height. The video was stable, all manageable (apart the gimbal "weird things" while was flying against the wind).
Once back home I did check both DAT file and airdata details, and I've been astonished looking how well it did behave in a very strong wind conditions: according to both sources the gusts were up tp 12/13 m/s and the MM wasn't moving around.
Just check on the below pic where the GPS lat and long are not changing while hovering at 75 meters.
I'm still not 100% sure about the safety limits of this AC, I need more practice.
That's incredible- I'm trying my best to understand all the data on that chart. I am a new pilot but also an avid kitesurfer. Our local area wind average is about 16 knots (8m/s). I know I could get some amazing footage of the kiters but I'm just nervous the mini will not be able to handle such winds but according to your data I should be okay, right?
I'm thinking the flyaways are more prevalent with folks flying out with the wind and drawing the battery down trying to return against the wind.
Reactions: Dbez1
It makes sense, actually it did run out the battery in 15 minutes
As said, I don’t get the safety limits yet. While it can manage to hover and move over a controlled field, I won’t use it in these conditions on a daily basis.
Reactions: Dbez1 and Dandada
how do you get this DAT data
fredguillot02
