Wisconsin greetings
Welcome to the forum! :)
Welcome to the Forum , Let us know what drone you have.
Gear to fly in the Rain, Capture the Storm.
Phantomrain.org
Air 2s, at least for now…. I’m more interested in photography and making short movies in post via Final Cut Pro. The 2S packs well enough in my adventure bike panniers and it’s a big enough bird to deal with more enthusiastic winds when out west like Wyoming. Decent enough video but licking my chops on some of the new cine stuff.
Reactions: LoudThunder
Hello everyone, great forum
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Wisconsin, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
edy44
