Would this be safe/legal to fly by UK laws
RaRaRasputin
West Midlands UK
Hi guys,
We have a castle that is local to us and I would love to get some footage of it (hopefully early Sunday morning)
I have gone on Google Earth and worked out a take-off point and added some radii rings at take-off point, for (a) 50 mtrs from take off, (b) 150 mtrs from take off and (c) 500 mtrs max flyable distance from take-off
The castle falls within the 500 metres radius
There will be nothing 50 mtrs from take-off
There are no mass groupings of people or built-up areas within 150 mtrs of take-off or the drone which I will keep high and fly initially in to the wooded area before approaching the castle
Does this look doable legally?
In the toolbar above the map there is a ruler icon
I set the type to circular and the unit type to metres - can use feet etc if you wish
Then just click a point and drag out, keeping an eye on the toolbox as the range increases to where you want it.
Don’t forget to save afterwards, you can then add multiple after saving
Reactions: Londroner
I take it you've checked to make sure that area isn't inside a NFZ?
Or owned by National Trust?
Otherwise I'd say you're good to go :)
Reactions: RaRaRasputin
Nothing on Airmap app or Drone Assist to say otherwise.
Think I will go for it.
Reactions: Ping^Spike
There's quite a lot of power infrastructure in the area, which will be best avoided in case of electromagnetic interference. You might be able to adapt your flight path to avoid. Check the location on Altitude Angle but you will need to zoom in to get the ground hazards. Apart from that looking good.
Which version of Google Earth are you using? I can't seem to find the ruler icon or toolbar in the current version.
Thanks
Google Earth Pro
At top of window do you have a Tools item in the main menu, next to the 'File' item ?
Or in the viewer window a row of tool icons like below
Is not Altitude Angel the same as Drone Assist ? Looks virtually identical.
I can see the power substations. I think it should be fine as they seem to be far enough away so as not to cause too much interference (if any)
Google Earth Pro
OK, got it, thanks. I was running Google Earth in my browser rather than the Pro version. Quickly rectified and now I have full control!
ryanhafeman
