WOW
Welcome to the forum! :)
I'm about to begin my drone journey
You don't say if you have already gotten a drone or you are still undecided on which one… But since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Whether you have flown Drones before, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Greetings: and welcome to the forum, from Chicago the Windy City.
FLY SAFE & FLY SMART.
Reactions: LoudThunder
mandeh
