3 warnings everytime
Mazdaman323lx
Cork Ireland
Is it just me or does everyone else get 3 " I take responsibility for this flight in this area " warnings one after the other on take off . Extremely annoying to have to click the check box 3 times on take off especially when flying in tight areas on take off with this repeat message blocking the screen view and causing unnecessary distraction .
I receive this warning but only once and only if I am in a area close to an airport. What do you mean by tight areas?
If taking off in a area where there are a lot of obstacles like overhead wires , near tree's etc , I get 3 of these warnings which have to be accepted on screen in the first minute of flight .
Interesting. I only have to do this once. Wonder if they are three different types of warnings?
Reactions: sarahb
What location? There may be three zones of concern in DJI's Fly Safe system.
I live in a class D space, i get the pop up sometimes
Have you checked a sectional or the DJI airspace chart? I often, but not always, get a notice like that when taking off from a friends house even though I am well clear of the Palmdale AFB class D and the DJI yellow area.
If you read the prompts it will say the cause, there's no warning whatsoever for flying in "tight" areas, they'll be about geofencing for sure, so probably you are under or close to controlled airspace.
Under controlled airspace there's probably an Aeroscope listening, so get the paperwork done or at least, be aware of what you are infringing and act accordingly (hit&run, etc), else they'll just screw you.
My house is very near a County Prison and I get warnings for that but not every time. I only get them once but finding the okay button on that message window is sometimes tricky. I specifically avoid ever flying that direction simply because if I ever lost contact and it did an automatic return to home, if I was flying somewhere in that direction it would overfly that airspace and I have no desire to tempt fate. It would probably mean nothing but I'm not finding out.
Gavthistle
