4K frame capture
bmwbob
California
When I look at the MA2 RAW photos and zoom in the quality isn't nealy 35mm quality, and the 4K videos look sharper and I'm wondering if you can capture individual frames and see the enlargement quality.
Those small sensor are fine for 4k, but not really for still pictures if needed to be cropped. If picture is what you are looking for, this is what I did 7 years ago. I got a large 6 motor drone, the DJI550, then attached to it the smallest camera with the largest sensor. I ended up using a Ricoh GR. The pictures where DSLR perfection.
Reactions: iaincaradoc
That's too far into the drone hobby for me. The existing sensor I'm sure will be fine up to 8x10.
Reactions: FlyoverDRN
This was the best I could do with a 4K frame capture from a MA2. But I don't really have any other options without a heavy-lifter, because I'd want to use a DSLR with a lightning trigger on it.
OkayOfay
