5.8Ghz, YAGI antennas template
PanX
Athens, Greece
If anyone wants to experiment with yagi antennas with minimal effort and expenses here is a template. Photocopy on white sticker paper and/or glue it on foam core board (3mm). Cut the perimeter with an x-acto blade. Use elements in any distance you like. The guides are 9.7mm apart. Quick, and cheap.
Elegantly simple :) . Basic corrugated cardboard would work too as a more widely available but slightly less durable alternative to 3mm foam board.
Reactions: Xanadu and PanX
If you want aluminium you can easy use these parts, can not recall the English word now:
I couldn't contain my excitement when I saw your post about the solution for metal rods, that's great, I spent precious time looking for materials to make the antenna. I have a 3d printer and I am creating variations of the yagi antenna. Thank you very much and sorry for the bad English
Reactions: PanX
TPS
