Active track minimum flight height?
gura87
Sweden
Hi!
I just joined after failing to Internet search my way to the answer of my question:
-What are the minimum flight heights for the different Mavic's in active track mode?
On YouTube it seems that most drones are stuck with filming people from slightly above, which I don't like.
Can any of the Mavic's do better?
The exception I've found is this one:
Really nice when he's running towards the drone.
Would appreciate your help. Thanks :-)
I usually use active tract facing me at a fairly low altitude and control the drone with the right stick. There is a minimum starting altitude but the drone can get much lower in undulating terrain. Caution required! The good part is I'm not always looking over my shoulder.
Thanks mate!
So you mean there is no height restriction in active track mode?
Also, what model is it that you are referring to?
soconnell
