Adjusting gimbal to specific angles.
Photodonn
Naples, FL
I want to do some 3D modeling and need to be able to control angle settings for specific angles. Is there a cheat sheet to make sure you can obtain the correct angle or is it guess work?
Not sure what you are after for angles. But I would pay close attention to the ginmbal angle gauge on the right of the screen and note the AGL. Then move to the other location and match both. You can even mark the gimbal angle on the screen with a marker, then wash it off the glass when done. Hope this helps.
wang
