Air 2s lens filter
Bsnyder
Nebraska
Did I miss something but I thought there was a clear glass cover that came on the air 2s combo, when I took this off the other day I was going to clean it and my finger poked through the filter ring. So Did it never have glass in it or did it fall out. If it didn't come with glass could someone recommend a clear filter to help protect the lens.
Thanks
Hmm, mine has glass. I just checked it again. I cleaned it a couple of days ago, it had glass then as well.
  • Wow
Reactions: tlswift58
You may have a filter if there is glass. Mine is just a cover with nothing in it. I run a ND anyway.
It's what came with my fly more combo installed. It's clear, I just bought this combo a couple of weeks ago, maybe they decided to put glass in them now, makes sense.
Are you all talking about the plastic protective gimbal lens cover that is supposed to be attached when transporting the drone to and fro?
OP, what is the assembly date on your drone? Should say it on the box, I believe mine is from April 2021
Thanks for the picture, is it glass or plastic, I can't imagine plastic not being prone to scratches.
Reactions: Hidden
Does any of you know a webshop, where you can buy a clear cover/filter for the drone? Just to protect the lens of the drone when flying.
I bought this uv filter from Amazon
5upp0r7
