Air 2S
Derek H
UK
I bought a new Air 2S and everytime I switch on I have to recalibrate the joy sticks. Is this normal, a fault or is there a switch I haven't seen. Apart from that all seems OK.
I learnt on Mavic Pro 1, which I still think is a really great drone.
Thanks Derek
What you describe is NOT normal. What message is it that tells you there is an issue?
Reactions: mavictk
Thanks Derek
What type of remote controller do you have? DJI RC Pro? RC-N1?
No not normal, sounds like there might be dirk in there causing it to give an error each time you start up. You could try some contact cleaner. Even still if the unit is new there should not be dirt causing you problems.
Had the same problem with my RCN1 controller for the Air2S. After a while, the joystick just malfunctioned.
I used a different controller now.
DigitalJoe
