@BTDT23 ,are you sure its the correct charger ,DJI lists a 65w or a 100w charger for that drone i have the 100w version which will charge the 3 batteries in the hub from 35% to full in around an hour each
Sorry you are correct, it is an 65 watt.@BTDT23 ,are you sure its the correct charger ,DJI lists a 65w or a 100w charger for that drone i have the 100w version which will charge the 3 batteries in the hub from 35% to full in around an hour each
I use a J5 Create 100 watt charger from Staples and it charges the batteries amazingly fast.My new DJI air 3 batteries are charging very slow and/or not fully charging. I am using the DJI 60 watt charger.
