Hello everybody; I lost my drone this morning on a river - "Aircraft disconnected" . 532 m away - the procedure RTH failed!! . How can I get the flight records ? ... thanks. I need to understand what happened !!
I lost mine as well about 2,500 ft away and 165 ft in altitude. This has happened several times before and all I had to do his activate "return to home". The aircraft founds its way to a reconnect and it came home. This time, after about 1 minute I still got the disconnected and it never reconnected. Does anyone know if the Mavic can be located using the GPS on the aircraft? Please help as this just happened at 10 am MST here in Arizona.Hello everybody; I lost my drone this morning on a river - "Aircraft disconnected" . 532 m away - the procedure RTH failed!! . How can I get the flight records ? ... thanks. I need to understand what happened !!
I appreciate your post - I found the "Find my drone" on the DJI Go 4 app. However, it is showing the Mavic in my back yard and it is not there. Any other suggestions?I lost mine as well about 2,500 ft away and 165 ft in altitude. This has happened several times before and all I had to do his activate "return to home". The aircraft founds its way to a reconnect and it came home. This time, after about 1 minute I still got the disconnected and it never reconnected. Does anyone know if the Mavic can be located using the GPS on the aircraft? Please help as this just happened at 10 am MST here in Arizona.
