Aircraft won't connect
cactus683
Any idea folks besides trying to re sync and bind already.Also my aircraft won't recognized in the dji assistant 2 app
Are you connected to the USB port at the back? If so you must disconnect the mini USB at the side. You cannot have both ports connected at the same time.
Nope only the one on the side,it's funny when I open the dji go 4 it says rc is connected but the aircraft is disconnected
did you ever get round to fixing this issue? i had a water crash, stripped down and cleaned and i have run into this issue
thanks
tony
jonwill89
