Almost lost her!!
You can also do this if you have no Wifi available - At the main screen within the DJI Go 4 app --> swipe one finger across screen to the left --> tap the HOME POINT AIRCRAFT button to set it's current location as home point, or tap the HOME POINT ME button to set the remote controller location as home point.
Reactions: R Ceballos
Normally before i take off after hearing homepoint recorded i check my map and before i slide it to take off, i put in a check in that precision landing box, which you have to have turned on in your setting, then i let it rise and do it's image taking and i go about flying, if i hit the RTH button, it comes back and land exactly where it took off from. (there is a precision landing box to check if its turned on in your setting)
YUP! agreed, this works great, and mine did this. What happened is that when I pressed RTH it switched my home point to a previous flights home point! I think completely shutting down the app after every flight is the fix to this!
Reactions: NestleQuik
hibachiwithus
