Altitude ceiling question
Bunyip
As I am still flying in beginner mode I want to know how the 30m ceiling is gauged, I want to take some footage over cliffs which are considerably higher and wonder if when I drift over from the cliff top where I will be will the drone drop to 30m or is it measured from the controller altitude.
I have no burning desire to find out the hard way and have to become a mountaineer to retrieve it from the bottom of the cliffs
AGL or at ground level so yes if you start high up in a mountain you can still go 30m from where you take off from..
Reactions: BIGLUG24
It will not drop over the edge of the cliff.
You will be ok it is 30m above ground level from where you took off
thanks, I thought it may be but didn't want to get caught out.
RalfDroneArtist
