Altitude Discrepancy
Top Hat
Took off from a local urban park @ ground level and took the MP out and up @ 75 ft high.
The park is wide open and no one was around so I was flying all over it a varying altitude.
Noticed that the batt is getting low I took it back closer and lower. This is when I noticed the discrepancy on altitude. I lowered the MP to 3 ft but to my estimation the actual alt of the MP is about 10' to 12'.
To make it more precise I brought it even closer and lower and dropped the alt further down to -11' but actually only a foot from the ground where it was hovering. What is wrong here and how can I correct this. Besides this issue I have no other problem to date.
mine does the opposite, it takes off from 0 on the ground. then when i bring it down to land it shows -14' or even up to -24 at ground level.
weird.
The barometric sensor for measuring altitude isn't all that accurate.
If you're able to repeat that consistently, then calibrate the IMU to see if it resolves the issue.
Reactions: Hushpuppy
I get this occasionally. Landing at -10m from original takeoff point etc. No biggie as the vps kicks in plus I bring it in visually, but makes you wonder what height the craft is really at up there and are we getting bogus telemetry
Reactions: josheleven11
Fairly common for me to "land" at -8ft or so. As above its not a very accurate altimeter and i dont think its temperature compensated so as the drone warms up from the electronics and being in the sun it drifts.
Its not an issue really.
Mine always goes negative - ie it ends up thinking its a bit higher than it actually is.
Hmm.. an old thread but I have the opposite problem with a student on the weekend. After flying around at about 1m for 5 minutes it was reporting he was 6 metres up.
JJDroner
