Very nice clip but certainly controversial at face value
Probably from MS FlightSim. LOLI'm gonna go out on a limb and say, "That's CGI and not real!"
It's going to get a LOT of attention and traction around the globe but something about it screams CGI.
I didn’t pay close attention at first, but I tend to agree. The video looks a little too “sharp,” but in particular the shadow on takeoff. It should get fuzzier as it climbs, and doesn’t appear to. Also, it seems like wingtip vortices would have caused a massive amount of turbulence as it passed - probably enough to destroy most drones, or even larger aircraft.I'm gonna go out on a limb and say, "That's CGI and not real!"
No guys - the shadow definitely looks real to me all the way through. This is totally outrageous.what about the 5 mile from the airport rule?
The SIM and the subject aircraft have the same markings because this Antonov AN-225 is the only one in the world.It was apparently added to MSFS 2020 around the end of May '21 and the plane in this video and the one from the so called drone shot have the same fuselage markings.
No - it's real. I downloaded the video and checked frame by frame. Far too much extraneous subtle detail and video artifacts for it to be CGI, including a beautiful display of dust blown up by the starboard wing vortex on takeoff roll, among other things.I'm gonna go out on a limb and say, "That's CGI and not real!"
That video is here. I'll believe it but it certainly would not be difficult to use a sim flight video for better understanding as an accompaneed video to add to the cockpit actual flight.No - it's real. I downloaded the video and checked frame by frame. Far too much extraneous subtle detail and video artifacts for it to be CGI, including a beautiful display of dust blown up by the starboard wing vortex on takeoff roll, among other things.
And I can tell you with reasonable certainty when it was shot. This was a departure to the NW on runway 33 from Kiev on July 5 2021 at 1353Z, heading for Leipzig. The sun azimuth was 268° at an elevation of 37°, which agrees exactly with the shadows in the video. Recorded weather that afternoon was fair/partly cloudy.
That certainly seems to confirm it was coordinated, but it's not shot with a long lens - that's obvious from the lack of foreshortening and the rate of yaw of the camera to follow the aircraft as it passes. The camera was less than 100 m from the aircraft, and note that no helicopter is in view from the cockpit on takeoff. It was clearly a drone.The video is real. What I question about it is - are we sure it was shot with a drone? With a little digging I found the original video from the pilot, I think they were making a promotional video. The shot from the air is using a very long lens attached to a very good camera - this is no consumer drone; if it is a drone at all. It is the long lens that produces a flat image that gives the feeling of something unusual about the video.
Original video - Skip to about 3:20 to see the take off from inside as well as the footage from outside.
And for comparison, here is a promotional video by Boeing that contains shots that don't look real (like the take-offs). Many of the clips in this video were shot from a helicopter.
Agreed - but that's not from a SIM.That video is here. I'll believe it but it certainly would not be difficult to use a sim flight video for better understanding as an accompaneed video to add to the cockpit actual flight.
