Regarding third party apps, as of the
Mini 3 Pro onward (Using DJI's MSDK v5) your only options for third party apps are :
- DJI RC Pro (expensive, but impressive)
- DJI RC N-1 w/ an Android device (a lot of screen size/etc options)
Apple/iOS is no longer supported as of v5 of the MSDK, but you can still use the official DJI Fly on iOS.
Far as the route, the DJI RC is rated at about 700nit for brightness, I ended up going with a Samsung Galaxy Tab Active 3, sort of a "poor man's Tripletek" in a way especially when both the Wifi and LTE models were on sale a while back (Got mine for a little under 400 for the 128GB model).
- 750 nit max boost brightness which stays on (doesn't fade in and out like some devices)
- Will be supported up to Android 15 due to being one of Samsung's enterprise devices (Currently runs Android 13)
- Has the same military grade durability to drops, heat, cold, water, etc as the TripleTek line
- Supports additional storage via micro-SD slot
- Has 4GB ram (versus the 8 you can get on the Tripletek running the older Android 10)
- Has a hard outer sleeve and pen that can be removed (works better in the tablet holder without, still retains it's ruggedness).
- Has a user-removable battery that can be replaced
- Performs rather well with DJI Fly, Dronelink, Litchi, etc
The older
Smart Controller can be used for third party apps, but isn't compatible with most the drones past the
Air 2S, and a lot of the smart controllers already have failing batteries due to age. They also cannot do any higher than Ocusync 2.0 (so going from an RC-N1 to a
Smart Controller, for the
Air 2S, you get less range/signal quality). Ideally it's better to just stick with the RC-N1 + Android device if you don't have anything else yet rather than invest money into the older
smart controller.
