Annoying Mini 3 pro gimble pause points when tilting
inim civam
Australia
When I tilt my gimble it often pauses during the tilt. This is extremely annoying when trying to capture a smooth recording with a large range of tilt.
While it seems slightly random it does always appear to be a multiple of 15 degree.
Anyone else notice this? Anyone know if it can be fixed?
I am not sure if this helps, but you can slow or increase the speed of the gimble by going to settings ~> control ~> Gain and Expo.
I saw this on YouTube by Drone Creative. It is about 14 minutes into the video titled 5 tips that make the DJI mini 3 pro even better. I will try to link it.
I really enjoy his videos.
Also I guess your name proves the theory that things do run backwards “Down Under” compared to the northern hemisphere.
Well thank you. You helped even though I didn't change a thing!
So I went into the gain setting, had a look at what they were, but didn't make any changes to them.
I then switched to cines mode and tilted through the entire range and it stalled once on the way down.
It didn't stall on the way back up.
I then switched to sport, then normal, then cine, trying full range each time and for the present moment at least the tilt stall seems to have gone, yay :)
Thing must have got confused what way up it was ;)
rejuwa
