Air 2 Another flight thru a Tunnel - long one this time
Nice! It kept my interest even with the longer length.
Were you actually flying through the tunnel or did you hand hold the drone/camera? I think I would be worried about screwy things happening.
The “Tunnel Master” takes things to the next level!! Faaaark! As if the forest isn’t flirting with enough danger! I know you have said you are in the tunnels for signal strength (I can’t see you in there though) How the hell do you manage to pull this off without GPS over that length in the dark? Simply amazing. ??????
Give us a hint ;) please!
Along with the piloting skills I'm impressed with the gradual exposure change as you exited the tunnel..I'm assuming that it was on auto?
The trick my friend is to commit to the flight , keep the drone moving forward . The forward momentum helps to minimize the drift caused by being in atti mode and any breeze moving through the tunnel . A good strobe is also beneficial to see it clearly in the darkness
Reactions: Vapor069
genoavoles
