reference SD Cards/slots - 1st flights today and installed a micro sd card into the slot above the Drone's battery - question is, "what is purpose of the sd slot on the RC Controller ?..................thank you, Bill
Nothing important .. the one that matters is the one in the drone.reference SD Cards/slots - 1st flights today and installed a micro sd card into the slot above the Drone's battery - question is, "what is purpose of the sd slot on the RC Controller ?..................thank you, Bill
The controller does not come with a card. You should be able to insert a card into the slot underneath the little door on the bottom of the controller. I've found both the drone and the controller to be a little stiff the first few times you insert a card.thank you.....so, is there a card already installed in the controller ? I couldn't tell and there's no getting one into the slot.....hmmmmm.....Bill
That better than having to take the ones out of the car camera.WAIT WAIT
You forgot an important reason to have a sad card in your controller.
WHEN YOU HAVE FORGOTTEN THE DRONE SD CARD OR IT GETS FULL It’s a great back up
