Another Question about Waypoint Flight and Gimbal Tilt
TexasStar15
Austin, Texas
If I plan a waypoint mission on my tablet and set the gimbal tilt to manual, when I go out and actually fly the mission, while I'm flying it can I change the gimbal tilt using the controller. I've notice when I have the gimbal tilt set to a specific value and flying a waypoint mission, you can't change that value unless you pause the mission. Thanks guys!
Check this YT video out to see if helps.
Ok I've finally figured it out thanks to this video
. According to the description, Here's a DJI Air 3 Waypoint Mission with all the waypoints set for manual camera heading and gimbal tilt set to "Manual." We have full freedom to yaw the aircraft left, right, and even backwards to aim the camera horizontally. And we have full control over the camera's gimbal to move it up and down over its full 90°-plus range. I will set one up and fly it tomorrow to test.
Reactions: GadgetGuy
I checked this video plus many others and read a lot of forum discussions. I still wants to know please how can I get " A SMOOTH" video from this? I have done all the settings including Hover, pause in flight, gimble & heading in manual but I can not save my changes so that I will record a smooth video from a pre-setup mission.
I managed to get a good video from flying to every waypoint, do all my adjustments to the gimble and nose direction and then save the waypoint/s by pressing C1. Then let the drone fly the mission. But I'm new to drones and not an expert flyer yet.
I have the same problems as in the video above - not smooth enough.
Phly858
