I have some photos that I took after filming in D-Log and forgot to put it back. Did some colorgrading and actually, it came out very nice. Would I do it again..? Nope. Would I be angry if I had to correct again, also no.
I wouldn't say that... Also in photography, the same rules apply. A good photo is a good photo. While a bad one remains bad. Including out of focusYeah, good point. I've taken some shots that were not well exposed that would have been salvageable had I used D-log. I guess if you're goal is to get the absolute best shot, the D-log is not good, if your goal is to avoid taking unusable shots then D-log is great.
Uh, no. Bits are bits, whether logged first or not. When decoded, you only get as many bits in output as you had on input. Because video is ALWAYS compressed (as was previously stated) a log transform, with the right parameters, can have a positive effect, depending on the result sought by the videographer. Because still raw is NOT compressed, you don't get the same benefit.What may not be obvious is this is really a discussion about Dynamic Range and quantization error.
The dual-ISO sensor gives more stops at the high end, so use 800 and above for bright scenes to reduce/eliminate washout. using below 800 switches to the stronger analog amplifier in the sensor reducing noise in low light, extending stops at the dark end of the sensor's range.
RAW doesn't help preserve detail lost in the ADC due to quantization error – analog levels between discrete digital levels that in fact represent detail in the shadows and dark areas, but is lost when they convert to the same digital value.
A log transform to the analog signal before ADC can preserve a lot of detail, but must be reversed in post, where there are more bits (levels) to work with.
So what you really want is dlog raw.
