So, let me start by saying I’m relatively new, got the Mavic day after Memorial Day.
I have since flow over 30 times and 6.5 hrs in total.
I have been using an iPhone 7 w/iOS 11 Beta, using side cable. Not a single issue except some high wind pop ups a couple of times.
On 7/1, I upgraded to the 9 firmware. Flew, no issues a couple other times.
Made my first trip away from my house, plugged in my iPhone. Powered up controller. Powered up Mav, launched app. Same steps I’ve taken for all flights. The Phone connect noise never happened. DJIGO4 app, won’t connect.
Quit app, relaunch, nothing.
Power everything down, backup, same sequence. App won’t connect.
While on,I unplugged the iPhone, plugged back in, and heard the connection tone and it then was connected.
So I’m flying....drone about 2k feet away, 200 ft up. App disconnects. I hit RTH as I make sure it’s set and when it got closer I manually landed it. Scary.
Change battery, restart everything and try again. This time I lose the video feed, while still flying I unplug the iPhone and back again, and it then was fine.
Flew a 3rd time no issues.
Yesterday, tested at home. Flew fine. No issues. Then took the drone to a friends. As I’m flying again about 2k feet away (plenty of LOS, and controller signal),App disconnects again.
I landed it, RTH,Then pulled that little cable out on the left side and used an iPhone USB I had in my car. No issues.
So I need thoughts, do you believe this is just that little cable going bad after being opened and closed 30+ times or, is this a firmware issue ?
I have Goggles coming and won’t use this cable again, however I’ve lost all the trust I’ve built up flying this last month.
