ATTI mode MA2
I dont think you can cause htere is no way to disable the gps. you can disable the sensors but this is only half of the required senario.
indoors or poor sat reception areas, forests etc.
Reactions: Squidinc
It might work if you block the gps signal (e.g. cover with foil or operate inside) and turn off the downward vision system (e.g cover the sensors with tape or fly in a low light environment)
I should have checked the manual. Page 11.
“ The aircraft automatically changes to Attitude (ATTI) mode when the Vision Systems are unavailable or disabled and when the GPS signal is weak or the compass experiences interference. In ATTI mode, the aircraft may be more easily affected by its surroundings. Environmental factors such as wind can result in horizontal shifting, which may present hazards, especially when flying in confined spaces. “
there are ways to change the parameters in the DJI assistant app and add atti mode. You would pretty much change the tripod mode to atti mode. You could change the sport mode instread but sport mode is usually more useful than tripod.
viliuss23
