Automatic Multiple Shots Photograph
Lucasheise
Brazul
Hi all, I'm quite new to the drone world and I'd like to know if there's a way to take a picture every x seconds on my mavic mini (eg: while in the air, press a button, and the mavic keeps taking pictures every 3 seconds until I press to stop).
Does anyone know if this is possible?
Thanks in advance
Ahh all right, that would be a really good feature
Yep - you have to wait until DJI releases the SDK for the Mavic Mini.
3rd party developers may then implement the feature you are wishing to use in their apps.
(Surveying/mapping apps make use of that feature)
Reactions: Lucasheise
Thanks in advance
No
It's currently not possible.
However, a 'workaround'/hack for now would be to record at the aircrafts highest resolution at say 25fps with a fairly high shutter speed to freeze the action and limit motion blur and then extract every 75th frame from a timeline.
Not perfect, not ideal but would probably get the job done.
No
Yeah, I guess that could work, only part I didn't understand is why every 75th frame? Thanks for the reply
The hardware compromises that DJI made to keep the Mini's weight and cost down are reasonable and, IMO, acceptable. The software limitations are harder to understand and much less forgivable. I've heard the theory that they don't want the Mini competing with their own more expensive drones, but if you look at the Mini's real competition -- e.g. the Anafi, the Zeno 2, the Fimi X8 SE -- and compare the features they provide, the Mini comes up way short. Until the SDK allows third-party apps to provide the missing features, I do believe the Mini is the least capable GPS drone on the market, and DJI deserves criticism for that.
Thanks in advance
Wait am I misunderstanding something here? I've been using that feature a few times on my mavic mini so yes you can.
Go to photo mode and choose timed shot, then the time between shots.
Thanks in advance
Yes there is an option in photo settings for time shot. i use it by mistake, thinking that it was for a delay timer, but it takes photos at a regular interval that you can setup.
Now I'm kinda confused, some people say it has this feature, other says it doesn't... I haven't been able to test it yet so I don't really know
That’s the problem sometime with forums. It is not intentional Mind you, but if someone posting hasn’t used a function they can assume it isn’t available. Leads to some confusion. I’ve done it myself. Easily sorted I suppose, but can be confusing to someone looking for answers.
The problem is that I wanted to know that before I'd buy, because that's a "deal breaker" for me (thats why I couldn't test it). But now I have the answer, thanks to everyone :)
Hi,
Here is a "demo" of timed shots feature that for sure exist on Mavic mini:
Reactions: ThorDar
M5P
