Battery clips
Max Headroom
England.
I have noticed a few threads about broken battery clips on Facebook the Mini 3 type batteries below are the ones that break (not sure what other models they fit) when searching for a solution i found this clip which looks like it could work but i cannot get my head around how it clips to the top, you can see in the first picture of the clip there are small hooks to hook under the body of the drone but if you look at the picture of the actual clip there doesn't seem to be any on the top part, how does it stay on?
Push down and click the bottom into place after alignment on top.
I have a m3p and haven’t had any issues with the battery or otherwise. Early on after reading a post years ago about how the clips could wear out on the inside of my MA2 I became over protective about snapping the battery into place. Several members here assured me I wouldn’t have a problem with it wearing out and should snap it in place for safety. So far so good. This cover does look to be a good solution for any issue with the battery slipping.
aquamusic
