- Joined
- Feb 14, 2019
- Messages
- 587
- Reactions
- 355
How many charging cycles can I expect out of my Mavic Pro batteries before it’s time to replace? Thanks!!!
The temperature difference could be down to many things. A difference in the signal from the sensor, its placement in the battery cell or casing. I’d check the external temperature of both OEM and aftermarket batteries using an external thermometer.The PowerExtra is ok. I possess two of them though I incline to use the OEM ones mostly due to the higher internal temperature (about 8-10C higher than OEM after about 20 minutes of flying). The PowerExtra battteries don't cause trouble and yield about the same amount of fly time duration overall. Just that higher than the OEM temperature does not make me feel ease.
I have about 60+ cycles on the PE batteries.
Fly safe.
Let me clarify here. The results that I mentioned above were performed under the same condition at about the same time back to back. The ambient temperature was stable. I even went to the extent of testing them in hovering mode to confirm the differences in temperatures. Trust me or please do your own tests and tell us otherwise.The temperature difference could be down to many things. A difference in the signal from the sensor, its placement in the battery cell or casing. I’d check the external temperature of both OEM and aftermarket batteries using an external thermometer.
