What did it say? Just "battery error" was your battery low? Are you on the latest FW and app?Does anyone know why I just received a battery Error warning at the top right of the go 4 app?
Gremlin, if you check your app under "errors" it may give you a little more info, I would not concern myself unless it happens again.Hi, yes I'm on latest firmware and my battery was on 87%. Yes it literally just said battery Error? I find it strange because I switched everything off and back on and then it disappeared
Regards,
-d.
Excellent mavic6611, glad to hear that you solved the problem. If you put "solved" in the title of the thread others will know to look here if they are experiencing similar issues. Congratulations.I contacted dji and they said to calibrate compass imu and transmitter. I never did any of that as it must have just been a bit glitchy that day because it's not happened on any other flights since
