Battery overheating
Meta4
During a Mavic 4 pro flight yesterday I had a battery overheating warning.
The same battery brought up the same warning last time it was used a week ago.
Both times the weather was cool.
Yesterday, the warning appeared when the battery reached 102°F and despite slowing down the temp continued to increase to 112°F when the drone landed.
The warning messages were:
Battery overheating. Stop flying and wait for battery temperature to return to normal. (Code: 16090080)
Battery power restricted. Aircraft performance decreased to ensure flight safety. Return to home promptly (Code: 110013).
The battery has 22 charge cycles and no swelling or other sign of a problem.
I've started a case and will be sending the battery back
I don't think I've heard of this warning before.
Has anyone else seen one of these?
If you had Airdata you could see how each cell is working, your problem may be a bad cell, I had a M3E battery go bad with no swelling and few cycles. I checked the info in Airdata which also sent me an email about the battery issue. I could see how the battery was spiking after only a few minuets of flight time.
Airdata shows the warnings in notifications, but nothing stands out in their battery data.
I checked the data for another flight on the same day with a different battery.
It went to 114°F without bringing up any warnings.
This suggests that the temperature is not the problem.
elescolta
