Battery problem
Andart
I have fly more combo , all three batteries initially charged , but today I went to put battery in drone and didn't have any green lights on battery .
I placed in charger and the light on the charger went to green for about a second then back to red .
Nothing happened to battery .
I then placed other two on charge with the dead one .
It cycled through the first two but third one still shows no green lights .
I've left it for 3 hours still no green light .
Any ideas or is it a dodgy battery
Sent from my SM-G935F using MavicPilots mobile app
Also, examine the pin connectors on the underside of the battery using a minimum of 10 power magnification. See if there are visible bent or broken connections that one could tweak to perhaps provide the proper connection.
Reactions: RallySoob
Same happened to me. I had three batteries on the charger. When I came back (days later). One was fully charged. The other two are completely dead. No lights and nothing happens when you put it on the charger with or without the hub.
How many flights are on these failing batterys?
Gustavodeamorim
