Best case that accommodates DJI prop holders?
easyheimer
Bristol CT
I have the prop holders from DJI and I’m looking for a case that will accommodate the Mavic Mini with the prop holders on without having to take them off. I found that the Fly More case that comes with the Mini was bending my props over time and wanted to prevent that. Unfortunately the Mini with the prop holders on doesn’t fit in the case.
Thanks!
there are many many cases for the MM and most of them hold the drone quite firmly ,and just looking at the picture on the web does not always show how much room there is around the section cut out for where the motors fit ,on every case i have, both for my MPP and MM i have had to modify them slightly to accommodate some add ons i have which i do not want to keep taking on or off the drone to allow them to fit ,these mods are quite easy to do as long as you get a case with the dense type of foam insert, that can be carefully shaped to fit the prop guards
Reactions: easyheimer
I have this case, and it holds my props nice and snug without any extras. Hope you find a solution you're happy with??
closer404
