Quick question.....under US & Canadian uUAV laws, is BLOS flying allowed on your private property or someone else who has given you permission?
Probably not. Because you are not flying "on" private property. Instead, you are flying "in" the airspace which may happen to be above your private property. The purpose of flying in VLOS is not to be aware of and avoid objects on the ground (although that is an obvious advantage), but to be aware of and avoid objects (aircraft) in the airspace in which you are flying.Quick question.....under US & Canadian uUAV laws, is BLOS flying allowed on your private property or someone else who has given you permission?
So... BLOS over your own property, below 400' (in the proper air-space that allows that height)? Or just ALL airspace?
Thanks everyone for your replies. This helps clarify the rules regarding flying from your own property.Although, when you read 903.03, special flight operations certificates are only applicable to UAVs that are 250g or over.
903.01 No person shall conduct any of the following operations using a remotely piloted aircraft system that includes a remotely piloted aircraft having a maximum take-off weight of 250 g (0.55 pounds) or more unless the person complies with the provisions of a special flight operations certificate.
(b) the operation of a system beyond visual line-of-sight, as referred to in subsection 901.11(2);
