I just bought a new Mavic pro from a 3rd party seller. It was clearly unused so I’m a bit confused as to why. I doubt dji will cover as I’m not the first buyer. Any suggestions??
I don’t but I’ll try and pick one up!Do you have another battery to see if that will charge. Sometimes we assume it is the battery only to find out it’s the charger.
Check the production date. If it’s been parked on shelf, may be doa.
Thank you sir! Are there any trusted after market batteries or do I need to stick to dji brand? I see a bunch on amazon.@Nooch13 from what you have said ,it would seem reasonable to surmise, that due to the batteries age that it has gone so flat, that it will no longer take on a charge you say its a mavic pro ,is it a MP1 or the mavic pro platinum ,the batteries for both those models are the same apart from the colour of the cases ,and you are more likely to be able to purchase MPP ones, as the original MP1 batteries are getting thin on the ground now
i am originally from Loughborough In Leicestershire, but have lived in Wales for over 40 + years and consider myself an adopted welshman nowThank you sir! Are there any trusted after market batteries or do I need to stick to dji brand? I see a bunch on amazon.
on another note, what part of the us are you from? I was stationed in Mildenhall and was a loosehead prop for Mildenhall and Bury St Edmonds.
BandH Camera in NY CityWhatever source you utilize, make sure they have a return policy so if this occurs again, you’re covered.
Just wishing you well, I'm in King's Lynn not to far from Mildenhall and Lakenheath.Thank you sir! Are there any trusted after market batteries or do I need to stick to dji brand? I see a bunch on amazon.
on another note, what part of the uk are you from? I was stationed in Mildenhall and was a loosehead prop for Mildenhall and Bury St Edmonds.
