Bwine f7 Am I welcome?
Hello from the Crossroads of America Thomas Argo .
Not a mavic pilot but a new Bwinef7 flyer interested. Can I jump in?
There is a sister Forum to the Mavic Pilots with a thread with your aircraft.
You might check it out.
Welcome to the Forum(s). :cool:
I appreciate the welcome. I have my FAA small cert of registration.
The F7 is 550 g.
Totally new at flying with only 2 batteries of time in the air. Excited to see the possibilities. Nervous has a new meaning. It has no avoidance but I feel it was a good place to start. I was a pro wedding photographer until I fell off a 90 ft cliff. This gets me back in the game from ground level for my internal titanium parts lol.
If I see the sister site correctly there is one post for bwine. I am going to hang out as a lurker until I can offer something. What I see here is a WOW read.
I see you already have been given the heads-up about DronePilots, and I also tried googling other forums that might serve you and your drone but no joy… I would advise you to visit YouTube and search for videos on you Drone.
Although you are not flying a DJI Drone, many of our members are also flying non-DJI drones and you might find some with your drone here. I hope we fill your expectations and don't be afraid to contribute the discourse…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Thanks all and to Loud, I like the phone number advice.
Reactions: LoudThunder
faridudinmuhammad
