Cable Help
Bytored
NCW
Just got a Mavic Pro Platinum and have a Mavmount on its way to use with an ipad. All i can find is cables that use adapters. I want one solid cable. Dont want to use an adapter. Anyone have any suggestions?
Same cable that come with your
iPhone will plug into the bottom of the controller and then into your iPad
Reactions: Bytored
Bottom plug is between the bat wings or phone grips
Just like this . These cables come in all lengths
Reactions: RJ111 and Bytored
You can get a 90 degree (right angle cable) which is better when using your iPad in landscape mode. That's if your using a lightning cable, not sure about the 30 pin plug.
Reactions: Bytored
Just picked one up yesterday!
Thor s Drone World has the coiled 90 degree usb to lightning cable. I use an ipad as well and have 2 of the cables from there. They are perfect for me.
RetVetPJ
