Camera won't focus
reneels
Hi All,
Has anyone encountered the issue of the camera not focusing. Last flight it was fine. When I turned it in today to to fly it the camera won't focus. I have reset camera setting and also recalibrated the gimbal. The drone is about 1 month old. Latest firmware.
Thanks
Rene
I get the green box. I tried the manual focus but still blurry. Lens looked clean, but I will check again.
Any other suggestions?
Mine will do this occasionally. I land and cycle the power and usually it is fine. It’s annoying as hell but it works like it’s supposed to most of the time.
I know this is a different matter but when I am flying the mavic and taking pics my histogram will always have mountains on the left no matter wat setting I use I can get mountains in middle but will still be on left as well. Any suggestions will be greatly appreciated
Just for fun, try using mavic with a different sd card.
I had this issue once and a corrupted sd was the problem.
Which doesn't really make any sense to me.
Reactions: Former Member
Ahh the black mountains of mavic you mean? :0)
It's only 1 month old. I'll also take out the SD card and see if it makes any difference.
Behind the glass on the camera is a tiny motherboard with just a cable running from that to a bigger motherboard on the Mavic. Im guessing it controls among other things the focus / zoom.
Tldr; The focus isn't working because the part posted above is ******.
JonesB17
