Cannot take off (Left Rear Wing Broken)
sohan
Hey guys, so I've ordered a replacement part for the left rear wing. So yesterday I turned on the MA to see what it says when I try to fly it. So the left rear motor is disconnected and it says "CANNOT TAKE OFF" is it due to the fact that the motor is disconnected or something else is gone wrong?
Most likely because it couldn't due the motor being disconnected .
What did you think it would say .
Reactions: Former Member
Thought it would say "Motor Obstructed". Is there anyway to check whether all the other functions except that broken arm is working fine?
Not that I know of but maybe our main fixeruper can tell us @Thunderdrones :)
The "motor obstructed" error message only applies to the gimbal.
ESC error would apply to the motor wires being disconnected or shorting out.
Is there any way to diagnose that all the other parts are working except for that one part?
I really don't think you are going to see any other errors till you replace that arm .
But I bet you will if you hit hard enough to do whatever to have and replace that arm
after you replace it .
Good luck .
Brett_GLP Drone Services
