Can't make warning go from screen
danstein
Received warning of airport area flight with caution...accept responsibility.
Pressing yes doesn't seems to be active. Warning doesn't go.
Have you pressed the “tick box” in the warning box you get on the screen, it’s very small and hard to see while in the field flying.
Reactions: brett8883 and MJ224
I had the same problem, it is hard to see the small circle that for me was on the right side of the warning box. I tapped that circle and then the YES. This worked!
Reactions: Bobvt
ATC_Marcoooo
